Old 11-13-2007, 10:45 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
removing key while car running???
OK, so I assume that it's not supposed to do this, but I can pull the key out while in "acc" mode, then tonight I noticed that it comes out while the car is started!! Don't think it's much of a problem. It's a '93 so it's probably just getting old. I'm not complaining. I also don't have to listen to the dinger while the door is open with key in ignition. Anyone else got this?
This ain't your grandma's car!!
Old 11-13-2007, 11:48 PM
bigtimmy45 bigtimmy45 is offline
Re: removing key while car running???
it happens with my '90 as well - as long as the car works I dont see a problem with it doing that as I just have let mine do that - for now, on mine, it is more trouble than its worth but it is on the list of things to eventually fix
Old 01-25-2008, 01:39 PM
lilloon lilloon is offline
it fine. dont worry bout it
Old 01-25-2008, 03:46 PM
16th hippy 16th hippy is offline
be ready to replace the lock cylinder eventually, but for now if you aren't worried about it, let it go. just make sure that when you turn car off, you put cylinder in locked position and it stays there without key in it. otherwise some dumbass can get in your car and drive off without the key.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 01-27-2008, 12:19 PM
j cAT j cAT is offline
[quote=16th hippy]be ready to replace the lock cylinder eventually, but for now if you aren't worried about it, let it go. just make sure that when you turn car off, you put cylinder in locked position and it stays there without key in it. otherwise some dumbass can get in your car and drive off without the key
the next thing that will occur is no key and the car will start or start with anything stuck in ignition key slot. rather than change sw i know a guy that used three kill switches that had to be thrown in a certain sequence to start engine
