Old 11-13-2007, 06:56 PM
Cantankerous's Avatar
Cantankerous Cantankerous is offline
95 PA Alarm problem
I just bought a 95 PA and I had the alarm system go off on me. of course I hadn't done my homework by reading the owners manual so I just disconnected all four horns and then found out all I had to do is use the key fob to stop the alarm system. Well now after I re-connected the all the horns up they don't work. Any Ideas?
Old 01-03-2008, 10:42 AM
kenneeds kenneeds is offline
Re: 95 PA Alarm problem
I also have issues with my 95 P.A. horn, and have been working on and researching their operation.
I suspect the issue with yours is either the 25 amp fuse located inside the car
on the right side of the passenger kick panel, which is accessed by removing the 3 screws in the lower right hand under dash access cover. The fuse is located toward the engine side of the fuse panel, and the second from the bottom I believe.
The second problem area could be the horn relay, which is in the engine compartment, on the left side of the firewall. It is hidden behind a long plastic cover secured by 2 wing nuts. I do not have specifics on the exact location, but searching on the 95 P.A horn relay should get you there.
I swapped mine with the A/C relay which is identical.
Good Luck,
Ken
Old 01-13-2008, 06:56 PM
Thanks kenneeds I will check out both of your suggestions. Good luck with your problem sorry I couldn't be of any assistants.
