Go Back   Automotive Forums Car Chat > Ford > Probe
Old 11-13-2007, 01:49 PM
mratzlaff mratzlaff is offline
90 Probe Rear Window Defroster
Mine doesn't work. I have ohm'd out the window and it does have continuity. There is no voltage to the window. The light in the switch on the dash works. The fuse is good. I removed the relay and looked at it - the points inside look like new. What else is there?
Old 11-14-2007, 11:43 AM
trackrat trackrat is offline
Re: 90 Probe Rear Window Defroster
There is a Defog C.B. button at the fuse panel. It is a rectanguler button with a little red dot on it. Push the button and make sure it's reset. If that's not the problem then there is a capacitor (C411) at the center of the rear hatch(on the body, not the liftgate) below the latch bar for the liftgate(hatch). Make sure that is good. It is a square silver capacitor. Make sure you have current there when the switch is on.
Also check your Defog (30A) AND Meter (15A) fuses. There are 2 fuses for this operation. The relay may look good but that still could be faulty.
If all of these are good and you still haven't remedied the problem then you are going to have to check for faults or grounds at several locations.
Check the above and let me know. I'll help you where to check for these problems.
Track.
Old 01-17-2008, 01:07 PM
I checked the Circuit Breaker and it was fine. I also checked both the 15A and the 30A fuses and they are good. I have tried to purchase a new Rear Window Relay at the auto parts store and they don't have it. I won't buy an electrical part like that at a wrecking yard, so I am still looking for a replacement relay (although mine looks good). How can I troubleshoot if it is a bad wire? Where do the wires run to the back window?
