Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-13-2007, 01:29 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Yet another tranny problem thread...
If you recall, I blew my tranny up back in May and got a rebuilt on installed with new clutch and all. It's made noises, but now it seems to be making more noises. The sound is comparable to a washer machine. It sounds like there's something almost floating around in the tranny. I've had no problems with shifting or the clutch. I'm going to drain out the fluid and see if there's metal in it. I found my receipt but it doesn't say how long the warranty was, but I think it was only 6 months. If there is metal or something in it... well I don't want to go there.
I still have the same problem when I'm starting out in first gear at low rpm, the car shakes and feels like slipage, but I think that's unrelated; happened before new tranny also.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-13-2007, 02:01 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Yet another tranny problem thread...
David - You seem to have a lot of problems no one knows the answers to...
Let know what happens when you drain the oil.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-13-2007, 02:19 PM
david-b's Avatar
Dave is THAT guy
Well let me expand on the clutch issue. When I fill the reservoir up, it works better. It doesn't get low, but it drops just a little. I fill up just a little and then it's fine. Sound like master/slave issue?
I don't want to drain the tranny. But no choice I guess. I mean it runs perfectly though. I would imagine if something broke (don't know how) that there would be an issue with running.
75 Monte Carlo
Old 11-13-2007, 02:38 PM
Holset powered 420a
Thats odd, it has to be something with your hydrolics then, or thats at least part of the problem. Maybe bleed the slave cylinder.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-13-2007, 02:48 PM
david-b's Avatar
Dave is THAT guy
What I should do for that problem is just take the whole clutch system apart, clean it all up and redo everything. When I did the spring remover mod I noticed that everything was pretty dirty inside which caught me off guard.
75 Monte Carlo
Old 11-13-2007, 04:27 PM
Holset powered 420a
That couldn't hurt.
98 Eclipse GS Turbo
2001 BMW 325i - DD
