Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 11-13-2007, 02:17 PM
soxfan04072 soxfan04072 is offline
2000 Venture - No blinkers
Hello,
I would appreciate any help you can give! My blinkers don't work at all - there is no fast blinking or no solid light when I try to turn on a blinker. The fuses appear to be fine. The four way flashers work.
Does anyone have a suggestion?
Thank you in adavance!
Old 11-16-2007, 12:33 PM
rockwood84 rockwood84 is offline
Re: 2000 Venture - No blinkers
the emergency flashers are on a different flasher. according to the haynes manual the turn signal flasher is located right below the steering column under the cover drivers side of dash.you have to pry the holding clips out to get the cover off.
Old 11-18-2007, 09:55 AM
Domestics_Only Domestics_Only is offline
do you have a diagram for this?
2002 GTP - My Baby
1999 Chev Venture - Beater - 2 problems down 1 to go (Rear wiper motor)
Old 11-22-2007, 09:53 AM
jhong1226's Avatar
jhong1226 jhong1226 is offline
there should only be 2 flasher relay there, take one and test it by swithcing thier places if that cures the problem with turn signal and hazards wont work then its the flasher thats bad. if thats the case buy one flasher then test by "trial and error".
jhong1226's Avatar
there might be a diagram behind the cover that youll going to pry out.
Old 11-22-2007, 10:27 PM
domestics-only, if you look under the dash on the driver's side you will see a usually grey cover that has some black round things about the size of a quarter these pry out. it is supposed to take a special tool to pull these out but you can do it with a wide flat screwdriver. put the screwdriver under the round black things and wiggle them out.once you have the cover out of the way look on the steering column you should see round silver flasher it is about the size of a fifty cent peice and 1 1/2 inches high this is the turn signal flasher. sometimes it will be under another cover it will be on the steering column a square box take the cover off and the flasher will be in there.get a turn signal flasher before you take everything off .if you don't booger the fastners up too bad you can reuse them to put the cover back on if you tear one or two up they sell them in a pack. let us know if this fixes it.
