Go Back   Automotive Forums Car Chat > Pontiac > G6
Old 11-13-2007, 11:50 AM
darshir's Avatar
darshir darshir is offline
How to Remove The CD radio
Hi All,
I was given a new CD radio system for my 2005 G6. Does anyone have any instructions as to how to take out the factory installed CD radio?
Thanks
Darwin
Old 11-13-2007, 12:46 PM
grfnkl's Avatar
grfnkl grfnkl is offline
Send a message via AIM to grfnkl
Re: How to Remove The CD radio
Sure not a problem. here's a link on how to remove the radio on the g6. Just scoll down to the section for the G6 specifically. Good luck.
Old 11-13-2007, 12:57 PM
darshir's Avatar
Thanks, this manual is a keeper.
Darwin
Old 11-13-2007, 03:27 PM
grfnkl's Avatar
Your welcome and Good luck!
Old 04-17-2008, 11:23 AM
timurdi timurdi is offline
Hey, Gm is actually now trying to stop odometer fraud, they make it more difficult on these cars for this reason, most perps were diconnecting the cluster from behind to stop the miles from adding up, now if that is done, the miles still add up because the factory radio records them as well, so in order for the miles to stop adding up, you would have no functioning gauges, radio, cd, info, fuel etc, this was the main reason for this design and many others like it.
Old 04-17-2008, 10:48 PM
grfnkl's Avatar
The radio does not control the odometer in anyway. The BCM has a memory chip in it that remembers the mileage on the car... and if that fails she speedo cluster has a back-up memory chip in it as well. The Radio on the 6's does have the extra DIC feature which gives you the trip odometer but that's it. So people can still change their head units out on there G6's if they want... and they make kits so you can keep the DIC controls on a separate unit.
Old 04-18-2008, 09:02 AM
Your reply sounds alot more accurate, I called Thompson pontiac and some 22-25 year old service rep said the radio has to stay in to control the mileage but theECM is actually where it is processed. Those deaers will say anything to make you feel answered, A simple I dont know would suffice, but then their customers would be unsure of there ability and an I dont know does not sound good, they are probably trained not to say I dont know to a customer. Anyway here isa question, I have a 2007 G6 GT covertable and there is an awful rattling coming from the inside of the quarter panel ares, mainly the right side, any ideas, also how can the govorner be removed, it shuts down at like 118 MPH or so, I got that 3.9 sport package andlive in an area with big wide open abadonedhighays at early hours so I would like to try ot the power but it shuts down, it feels like the gas just stops to the engine even if the pedal is to the floor, then when it slows down to about105ish it goes again only to shut off at 115-118, if I had known this, I may have thought twice about getting it, can itbe adjusted or removed???? also, where is the ECM??? is it under the passenger kick panel, does the ecm control the governer as well a s the odo??? can I get an after market with no governer, disconnect the governer....HELP
Old 04-18-2008, 09:11 AM
Old 04-18-2008, 09:13 AM
grfnkl's Avatar
dealers will tell you things like that to hold people back from changing out radios among other things and screwing up electrical components of the car.
For the rattle, your just gonna have to hunt down the source of the noise. It could be the supports to the roof that need tightening could be a loose piece of plastic.
For the Speed limiter. Your best bet would be to get a tune for your ECM. It will allow you to go faster and get better MPG...depending on the tune you get. I know they have an 87 tune which allows the car to run on 87 gas, and a 93 tune which requires the car to run on 93 octane. After the tune you will have to do a case relearn though. The last i had heard the ecm should be somewhere on the passenger side kick panel. I haven't dug mine out yet.
Old 04-18-2008, 09:19 AM
Hey, what is a tune for the ECM, where do I get one, can I do it myself? how much does it or they cost???
grfnkl's Avatar
PM being sent.
Old 04-18-2008, 10:07 AM
Ok, I got it, I need some advice though, I dont wanna get ripped off. I found a shop that will do a 93 octane tune, he claims it will increase speed limiter from stock 115 to 130 add hjorsepower, increase shifting perfomance by quicker shifts, etc, My question is, I have a 07' G6 GT convertable with a 3.9 engine, it has this option on the stick so I can use it as a manual or auto, when used as a manual will the shift be quicker too or only whe in auto (D)? he said 550 bucks for the tune, is that too much for what I have, is there a tune to completely remove the speed limiter?
Old 04-18-2008, 11:28 AM
grfnkl's Avatar
the tune will only increase the speed limiter but not remove it entirely. once you hit the 120 mark in these cars they get awefully light and squirrely so i would be careful one wanting to go that fast... and non the less in a vert. I don't know of any that removes the limiter though. The shifting will improve for the automatic trans. The manual mode shouldn't change much or at all since you are in control of the shifts. The price doens't sound bad I believe thats about the going rate... I know some people have gotten it cheaper and some have paid more but I believe thats about the average.
Old 08-04-2008, 10:46 PM
A-Dog A-Dog is offline
Hey, the link you listed is now dead. Can anyone repost?
Thanks!
Old 08-14-2008, 02:31 PM
grfnkl's Avatar
Sorry for the delay I haven't been on as much recently Here's a new link which I know will work with the radio removal for the g6.... LINK
