Go Back   Automotive Forums Car Chat > Nissan > Quest | Presage | Serena
Old 11-12-2007, 11:25 PM
yurkom yurkom is offline
1999 Nissan Quest MIL light
How can I turn the MIL light off in my 1999 Nissan Quest without visiting mechanic?
Old 11-12-2007, 11:47 PM
chubbybubba1 chubbybubba1 is offline
Re: 1999 Nissan Quest MIL light
Autozone and have them read the code and then clear it for you. It will most likely come back on if there is an underlying problem that doesn't get repaired.
Old 01-16-2008, 08:06 PM
mmcpeck mmcpeck is offline
You can also buy your own scanner, that reads codes and clears them, if you work on your own cars. I got mine at Sears for about $110 or so.
Old 02-12-2008, 07:40 PM
Re: 1999 Nissan Quest head lights replacement
Can I replace head light bulb without opening up the whole box?
I can see condensation on the inside side of the glass. Can this contribute to the fact this bulb goes more often out than the other?
Old 02-12-2008, 10:23 PM
Pop the hood. Find the wire harness that goes to the headlight bulb in question. It's accessed through the rear of the headlight assembly in other words.
Sounds like you need to install a used assembly if your getting water inside. That bulb burns hot and having water get onto it will burn it out.
