Old 11-12-2007, 08:40 PM
bgtony65 bgtony65 is offline
Send a message via Yahoo to bgtony65
Post 1999 bravada brake problem !!!
Originally Posted by bgtony65
hello i have a 1999 bravada all wheel drive with 4 wheel disc brakes. i changed the pads all around the rotors were good didn't need to be cut, now my 2 rear brakes are real tight and are getting really hot and sometimes they stop the truck from moving!!! can anyone give me an idea of what could be wrong. thanks bgtony65( tony )
Old 11-12-2007, 08:48 PM
old_master's Avatar
Advisor/Moderator
Re: 1999 bravada brake problem !!!
Very common for the guides to seize up. Remanufactured calipers are available with all of the hardware and the brackets. Should be done each time the brakes are done, along with either replacing, or at the bare minimum, resurfacing the rotors. Here is a link to the part: http://www.partsamerica.com/ProductD...e=5003&PTSet=A
Old 11-13-2007, 05:31 AM
thank you for the help.
