Old 11-12-2007, 06:35 PM
flapper10 flapper10 is offline
idle problems
1997 blazer idles too fast,1000 RPM in park. 2000 rpm in drive. I have changed the idle sensor and the MAF sensor. Also installed a new throttle body seal. Problem still there. HELP! (310,000) on engine.
Old 11-12-2007, 08:10 PM
old_master's Avatar
Advisor/Moderator
Re: idle problems
Does the Service Engine Soon (SES) light work? If it does, what are the Diagnostic Trouble Codes (DTC's) in memory?
Old 11-12-2007, 08:43 PM
Re: idle problems
They are none.
Old 11-12-2007, 09:35 PM
old_master's Avatar
Advisor/Moderator
Re: idle problems
Does the SES light come on when the key is turned to the RUN position and go off after the engine is running?
