2000 Grand Am passlock problem????
2000 Grand Am SE 2 door, 2.4L
Ok here we go.... first off the security light was on STEADY with the key on, tried the ten minute thing to no avail. Then did the 30 min thing (10x3) to no avail. So after much reading and talking to different people i decided to buy a scanning tool, and a new lock cylinder. Installed the cylinder, went through the relearn steps and bamo the car still wont start. BUT the security light does not stay on now. I am at a loss, also the scanner has NEVER showed any codes, not a one. I have checked to see if I have pressure at the fuel rail and it is good. I hate to just buy and throw parts at my problem, but the dealer is a hugh cost........I am at my witts end with this, I was thinking that maybe the scan tool I bought is a POS, but I cant move my car to get it to a better scanner. Any thoughts??? (I have try starting the car without the hall effect sensor hooked up so it would give me the code so I could clear it, but my scan tool never showed the code......) |
Re: 2000 Grand Am passlock problem????
Welcome to AF.
Not all scan tools are created equal, that being said some are junk and some are not. Most of any DTC's you would get from a passlock error not many scan tools will read them, just the GM tech II. Another thing you might have done the relearn wrong..... should be 11 minutes. ![]() Also if you disconnected the crank sensor, and it thinks its been replaced, then you might have other issues as sometimes when it's replaced, you have to do a relearn also, yeah cars suck!Try this !! Quote:
1999 Grand Am SS 3.4 OHV
First off thank you for the fast reply!!!!
I have tried what you express, I have turned it to on left it for more than 11 mins probaly closer to twenty each time and then tried to start it to no avail. If the code is not cleared after I replaced the lock cylinder, could this be the problem??? |
OK maybe this will help some of yall out there. I changed the lock cylinder as I stated b4 and the security light was out. And I did all the relearn stuff to no avail and the security light was out, but from what I had read on several tech tips sites this is it:
PASSLOCK The Passlock system is designed to prevent vehicle operation if the key is not used to start the vehicle. The key, which does not contain a resistor will turn the Passlock lock cylinder. The Passlock lock cylinder will relay a resistance code to the instrument panel cluster (IPC). It does this by rotating a magnet past a stationary hall effect sensor, creating a resistance code. At this point the IPC will determine if the resistance code is correct and within an acceptable time frame. If the code is correct, the IPC will send a coded password to the powertrain control module (PCM). If the PCM receives the correct password, it will allow the fuel injectors to operate normally and the vehicle will start and run normally. If the correct resistance code from the lock cylinder is not received within the acceptable time frame, the vehicle will go into a short tamper mode during which the theft deterrent system will not allow the vehicle to operate for approximately 4 seconds. When this occurs, the security indicator will flash. After three consecutive failed tries, the system will enter into a long tamper mode. In this mode, the fuel injectors will be disabled for approximately 10 minutes, and the security indicator will be flashing. Please note that in any of the tamper modes, the vehicle may start, but it will quickly stall. The Passlock system is designed to prevent vehicle theft even if any of the theft deterrent parts are replaced. Passlock eliminates the need for the key mounted resistor. Parts that can no longer be replaced without the possibility of the system going into a tamper mode and prevent starting are: the lock cylinder, the instrument panel cluster (IPC), and the powertrain control module (PCM). In order to initiate the relearn: 1. Hook up your scan tool to erase any of the passlock/vehicle theft deterrent trouble codes. If there are any other codes, note them before you erase them, so you may address them after the relearn has been completed. 2. With the ignition key in the “On” position from the code-clearing step, attempt to start the vehicle. At this point, if the vehicle starts, and the security light has not illuminated, a relearn is not necessary, and you’re done. If the vehicle starts and stalls, leave the key in the “Run” position and wait for the “Security” light to turn off. This will take approximately 10 minutes. At any time during this relearn, the light may flash or be on steady. If the ignition switch is turned off at any time during this relearn cycle that the security light is illuminated, the entire cycle must be restarted from the beginning. For most cars, one cycle will be sufficient for the relearn. If the vehicle will not start after the first cycle, then continue the process from step #3 to the end. Most trucks will require that you continue from step #3 to the end. 3. When the light turns off, turn the ignition switch to the “Off” position for approximately ten seconds. 4. Next, repeat steps 2 and 3 two more times for a total of three cycles. After the third time, the new code will be relearned on the next start attempt when the ignition switch is rotated from the “Off” position. 5. From the “Off” position, start the vehicle, observing the security light. If the vehicle starts and runs normally, and the security light is off, the relearn is complete. If the vehicle does not start, check for trouble codes before proceeding further. After all this still no start. Somehow the passlock MAJOR malfunctions caused a B code failure, if I remember correctly it was B1363, which the tech that came to the house said was a ignition circuit failure. Total money invested: $148 for the lock cylinder and 95 for the house call, it took the tech less than 10 minutes with his fancy umteen thousand dollar scanner to get it running.......He did state that there were no P codes just the one B code, FWIW. Good luck to the rest of yall with this problem!!!!!! |
Thankx for all that hundredand1aces.
The B1363 is Ignition Start Circuit Failure, which would lead me to believe the ignition switch is bad not the lock cylinder. Another typical GM DTC for a passlock problems.
I have a similar question/problem with my 2001 Grand Am. It has locked me out multiple times in the past (by lock out, I mean put the security light on and not let me in for 10 minutes in freezing weather) and now the light just comes on randomly but still lets me start my car and drive normally....any suggestions?
If thats the case then I doubt its a passlock issue. Maybe your keyfob battery is dead.. ![]() If your security light is on it could be several different things and with out scanning it with the proper tool you wont know why. But I will say, if you have many things hanging from your key chain, remove anything unnecessary. Thier is a trouble shooting bulliton(TSB) from GM pertaining to this issue and security light being illuminated. Hope that helps.
