Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 11-12-2007, 03:57 PM
drumcat's Avatar
drumcat drumcat is offline
Engine Block Numbers
Hey, I just recently got my hands on wha tis supposedly an LT1, I've searched all over the internet trying to verify that it is indeed an LT1. If you guys could help that would be great. All I really found out was that it was built at the Flint manufacturing plant, and that it was made on July 8th.
Thanks!
Block Code: V0708SAU
Old 11-17-2007, 05:04 PM
The Right Formula's Avatar
The Right Formula The Right Formula is offline
Send a message via AIM to The Right Formula
Re: Engine Block Numbers
Thanks!
Does it look like this: http://www.eskimo.com/~cjessup/jpgs/...l/lt1-383f.jpg
or this: http://transamws6.com/pics/transam/lt1_front.jpg
2002 Light Pewter Metallic Formula A4:
Cold Air Intake with sealed MTI Airlid, ported and polished TB, smooth bellows
Old 11-18-2007, 06:16 PM
drumcat's Avatar
I think it's closer to the engine out of the WS6 but I'll have to find out tomorow when I go to my shop
Old 11-21-2007, 10:34 AM
What year WS6?
Old 11-22-2007, 06:57 PM
drumcat's Avatar
I was just talking about the website, it was off of www.transamws6.com
Old 11-23-2007, 03:42 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Is there a 327 stamped into the block?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-25-2007, 08:34 PM
drumcat's Avatar
Yes there is a 327 stamped into the block
Old 11-26-2007, 02:41 PM
FormulaLT1's Avatar
Fight the powwa!!!
Its a LT1 then.
Old 11-27-2007, 03:48 PM
drumcat's Avatar
I just wish I could I could figure out which year it was from, and what car it was in
Old 11-27-2007, 09:27 PM
FormulaLT1's Avatar
Fight the powwa!!!
Is the engine complete? or is it just a block?. If it has aluminium heads its from a F-body or corvette. If its Iron heads, its from a Impala or caprice. If its a Aluminum heads with non vented opti, right side accesory bracket and intake manifold without fuel rail crossover on throttle body side its from a 93 (also has oil sender unit on side of block instead of behind intake manifold(left side bracket means its from a vette, also vette has a real thick crank pulley and 4 bolt mains).
If it has aluminium heads with non vented opti, right side accesory bracket and has cross over for rail on manifold and oil pressure sender behind intake manifold. Its a 94 F-body (same rule as 93 for the Corvette)
Before I go on for like 3 pages. If you can take a pic or check if it has aluminium heads, vented or unvented opti, has a crank position sensor in the timing cover or not, right or left accesory bracket and measure thickness of crank pulley, also a description of where the head cooling cross over line comes (Y-bodys come out on passenger side of block, while f-bodys come out between intake manifold and valve cover).
Old 11-28-2007, 07:26 PM
drumcat's Avatar
Haha, thanks man. Yeah I'll get a picture for you. I appreciate all the help. I have the whole enigne, just parted out.
