Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 11-12-2007, 04:57 PM
Retired Jim Retired Jim is offline
Crank Position Sensor & Tach
97 Trans Sport 3.4L
I just replaced my timing belt cover gasket. I removed and replaced the existing crank sensor( 24X) . I am now getting CODE 336 Crank Position Sensor. The TACH is also not working. The van drives fine. Are these two issues connected? If RTV sealer got between the sensor and engine could this be the problem?
As I read further in my HAYNES book it states that anytime the crank sensor is disturbed it will set off a false trouble code. It also says that I must take it to a dealer to have a LEARNING PROCEDURE done. What in the world is that and is there a home mechanic remedy.
THANKS FOR THE HELP !!!!
Jim
Old 11-12-2007, 08:32 PM
LMP's Avatar
LMP LMP is offline
Re: Crank Position Sensor & Tach
The learn procedure is about idle air control valve adjustment.
more here
http://www.bstuff.com/index.php?show...aded&pid=73002
www.avigex.ca/xport/IAClearn31.jpg the last 4 lines...
also autozone prints:
To reset the IAC pintle position.
With the key OFF ; depress the accelerator pedal slightly.
Start and run the engine for five seconds.
Turn the ignition OFF for ten seconds.
Restart the engine and check for proper idle operation. .
If your vehicle idles correctly, it means it has learned already by itself, which it can
THe sensor is magnetic..hence sealer is not involved...I've no idea why it would not work but the tach depends on it most probably...all of this goes through the ECM...so it is not hard wired as such.
ALso, all diagrams for the '97 here:
http://www.autolib.diakom.ru/CAR/Pon...NG%20DIAGRAMS/
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
