Old 11-12-2007, 03:49 PM
ronjon_4's Avatar
ronjon_4 ronjon_4 is offline
Rear wheel bearing?
My 94 grand prix se has a sound that seems to be coming from the driver rear tire. It actually sounds like the brake pad rubs harder against the rotor at a certain point. As i speed up, so does the sound. It is like a light scraping sound. Maybe its normal or the rotor is just warped but want to make sure its not a bearing or something. I believe thats more of a squealing sound but again not sure. Thanks!!!
Ryan
Old 11-13-2007, 04:24 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Rear wheel bearing?
This certainly sounds like a rear wheel bearing going bad especially since the sound increases and speeds up when you speed the car up.
Old 11-13-2007, 09:24 PM
ronjon_4's Avatar
well thats no good. Would there be a squealing sound of any sort or will it sound like something is just scraping? Hope its not to difficult to replace. Thanks
Old 11-14-2007, 08:12 AM
Pontiac Guy
It should sound like a rubbing noise or possibly a scraping. If it squeals then it is probably a brake but you would only hear it while braking. Usually caused by the wear indicator contacting the rotor.
Old 11-15-2007, 03:18 PM
ronjon_4's Avatar
Gotcha. Yeah the pads are fine just replaced them not to long ago. Guess I will look into (1) wheel bearing replacement. thanks!!
Old 11-16-2007, 06:58 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
these cars are known for the rear caliper slides freezing up. This will cause the pads to constantly rub. Also, when you replaced the rear pads, did you replace the hardware too? Worn hardware can allow the pads to move around and fall back against the rotor when the brakes are not applied causing a rubbing noise.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-21-2007, 01:14 PM
ronjon_4's Avatar
I just replaced the pads but will look into some new hardware and see if that fixes the prob. thanks!
