Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-12-2007, 02:30 PM
CHEVYMAN1994 CHEVYMAN1994 is offline
my camaro wont start
does anyone no why my car wont start i have changed my starter battery and alternator and fuses . my dash lights wont come on like my car has no juice at all it wont kick over nothing at all just no life??
Old 11-12-2007, 02:44 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: my camaro wont start
If you have ZERO pwer to anything, at all times, it owuld have to be a broken power supply or ground cable.
Old 11-12-2007, 02:46 PM
zero power at all times i mean my car wont start at all no power to the dash nothing at all as if no battery in it at all but i replaced my started batter alternator and fuses
Old 11-12-2007, 02:47 PM
gmack221's Avatar
gmack221 gmack221 is offline
First of all, (year - make - engine size - transmission) usually help diagnosis the problem easier ...
Are you getting any power to the interior of the car? headlight work?
I can think of two things that would give you problems
1. If you have no power anywhere but have a good battery, you either have a bad battery cable or ground.
2. If your not getting any power to the interior of the car (check the fuse box with a test light or volt meter) You probably have a bad fuseable link (usually near the starter, breaks the power into 4+ wires that feed the fuse box, computer ... ect) follow your + battery cable you will find them ... if you have one bad (test by probing on both sides with a test light) you will need to get one from an auto parts store, cut & replace it.
again with the info given I'm taking a shot in the dark, but this should atleast give you a place to start ... post additional info & maybe one of us can help more!
Old 11-12-2007, 02:48 PM
1994 camaro v6 i believe 3.4l
Old 11-12-2007, 02:51 PM
also automatic sorry
