Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-12-2007, 03:03 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
My GF's tranny problem
I know its not a DSM but.....my girl has a 98 Ford Contour Sport with a 2.5 V6 (a joke.) Anyway, her car is auto and when he car accelerates the shift from 1st to 2nd gear kicks like a fucking horse! 2nd to 3rd is still pretty bad and 3rd to 4th is still pretty noticeable. Any idea as to what this might be? The shift points are still the same, its just a really bad jerking.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 11-12-2007, 04:27 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: My GF's tranny problem
Check fluid level in the tranny. Change the tranny fluid and filter.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-12-2007, 05:43 PM
JoeShmoe's Avatar
She took it to the shop and I believe they changed her tranny fluid, as far as the filter I'm not sure (probably not.)
***EDIT***
Her filter was not changed, damn that means i have to drain it again.
Old 11-12-2007, 10:58 PM
Holset powered 420a
I would think they should have changed it. Maybe it doesn't have one, I dont really know.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-12-2007, 11:14 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Transmission are so touchy. I hate auto trannys. Anyways, They may not have changed the filter. Anytime I have changed tranny fluid I change the filter to. But some shops probably won't change the filter, but I don't blame them. If a transmission is old and the fluid and filter have never been changed....you don't want to change them, unless you start to have problems like you did. If your transmission is old but works fine and you change the filter and oil....its a good chance it won't ever work right again. Its a toss up. Whoever worked on yours may not have even took the pan off the bottom, just pumped the fluid out and put fresh fluid in.
Some places are real anal about that. My friend is a bus mechanic and the pan bolts on the bus's are tamper proof. So if a bus is under warranty and the tranny goes out, the first thing the manufacturer will do is look at the pan bolts to see if they have been removed to change the filter, if they have then the warranty is canceled and you are SOL.
But about your problem, I'm not sure, I'd change the filter and oil again myself and see what happens.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 11-13-2007, 03:17 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah, I think its just a sign of a worn out tranny, and if its got less than like 150k+ on it, its just not been maintained like it should have. I'm not good with auto trannies, but that is about what I have gathered.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-13-2007, 09:16 AM
JoeShmoe's Avatar
I don't know if it has a filter or not but I'll look at it this weekend. Solenoids maybe? I blew some solenoids on my car once because i was using the O/D, i wasn't pulling anyhing but i just liked the extra power of having it off. Anyway i paid $2k to get them replaced!
Old 11-13-2007, 02:25 PM
2K, yeah I think you got ripped son.
Caleb
vanilla gorilla
Old 11-13-2007, 02:46 PM
JoeShmoe's Avatar
They bent me over and gave it to me.
That was before i really got into cars though, you can bet our ass i'm not gonna pay for any more expensive fixes if i can do it myself.
Old 11-13-2007, 04:11 PM
JoeShmoe's Avatar
Exclamation Re: My GF's tranny problem
Just got done reading some other forums, looks like it probabably is the turbine shaft speed sensor. I also read that the tranny has to be yanked out in order to replace this deffective part
Anyone ever do tis before on nay car?
