Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-12-2007, 10:21 AM
at1212b at1212b is offline
Will Roadmaster rims fit 94 Lt1?
I'm looking to get a set of rims for the winter and came across an ad for SNOW TIRES ON RIMS P225/75R15 AND WHEELS
4 STEEL WHEELS OFF OF A 1996 BUICK ROADMASTER.
-Will this fit the 94 Caprice?
TIRES HAVE 50-60% TREAD LEFT
-Is this reasonable to use for witner? Or too worn out?
Old 11-12-2007, 10:33 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Will Roadmaster rims fit 94 Lt1?
I believe they will fit. I am using '92 Caprice rims with snows on my '95 Roadmaster, and they fit. 50 to 60% should still be sufficient, just make sure the price they are asking or you are offering reflects this fact.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 11-12-2007, 01:14 PM
Its listed for 200 o.b.o. so I was thinking of offering 150 if it does fit.
I have the 9C1 Lt1 with the 4 wheel disc brakes, so was just wondering if they would be compatible with rims from a 'civilian' Roadmaster.
Old 11-12-2007, 01:28 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Yes, they will fit. I am running aftermarket 15" wheels on a rear axle/front suspension from a '94 9C1. They clear the calipers on the rear axle fine.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-12-2007, 02:09 PM
Cool, thank you for the info!
Old 11-13-2007, 01:11 AM
hondahappy86 hondahappy86 is offline
hey....well i know civi caprices had a 5 on 4.5 bolt pattern....i have a 94 9c1 and mine is 5 on 5....so id have the bolt pattern measured
Old 11-13-2007, 09:43 AM
GreyGoose006 GreyGoose006 is offline
civies have a 5 on 4.75
most 9c1 had 5 on 5, but some came with 5 on 4.75
Old 11-13-2007, 10:03 AM
silicon212's Avatar
Confoundingly Lucid
Not the '91-up - they ALL had 5 on 5.
Old 11-22-2007, 02:12 PM
Unfortunately when I tried contacting the seller, I didn't get a response, and the ad had disappeared.
I came across another ad from a GMC Safari Cargo Van.
215 75 R15 - Bolt pattern is 5x127 according to the ad.
Will this work at all?
Old 11-22-2007, 07:17 PM
CD Smalley CD Smalley is offline
Astro wheels are 5x5 and should fit as well.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 01-15-2008, 02:42 PM
BigLou101 BigLou101 is offline
astro van wheels fit its what im currently running
