Old 11-12-2007, 08:33 AM
KidRock9999 KidRock9999 is offline
My 1992 Taurus Idling Problems
My Car idles like its going 55mph, when it idles up high, it will not go back down and causes the car to jerk into drive and reverse, i need to know 2 things, Is it the Throttle Position Sensor and where is it located? Can i change the myself?
Old 11-12-2007, 08:52 AM
Blaze_316_316 Blaze_316_316 is offline
Send a message via MSN to Blaze_316_316 Send a message via Yahoo to Blaze_316_316
Re: My 1992 Taurus Idling Problems
need to kno a bit more about the style of motor what size? and TPS can be changed by yourself its 2 bolts/screws, should be right on the Throttle body.
200 Hp Quad 4 H.O. W41 Cams + Prom,
Rebuilt Motor
90 Cutlass Supreme International Quad 4 HO 5 SPD
91 Grand AM SE Quad 4 HO 5 SPD
92 Grand AM SE Quad 4 LO 3 Spd Auto
Old 11-12-2007, 08:57 AM
its a Taurus L 3.0 V6, what is it near, do you think that is the problem?
Old 11-12-2007, 09:09 AM
is that a "vulcan" engine?
Rebuilt Motor
Old 11-12-2007, 09:10 AM
not sure about that
Old 11-12-2007, 09:12 AM
Does it look like this motor?? http://en.wikipedia.org/wiki/Ford_Vulcan_engine
Rebuilt Motor
Old 11-12-2007, 09:14 AM
no it doesnt
Old 11-12-2007, 09:20 AM
http://memimage.cardomain.net/member...560_2_full.jpg this motor correct? i am not familiar with ford, i would never buy 1, too many issues
Rebuilt Motor
Old 11-12-2007, 09:22 AM
yes thats mine
Old 11-12-2007, 09:40 AM
Cool Re: My 1992 Taurus Idling Problems
sorry its probably not what your looking for but i searched my data bases and came up with this http://www.autozone.com/images/cds/g...3d801af809.gif
or try this for step by step let me kno if this helps you
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
TRY THIS ^^
Rebuilt Motor
Old 11-12-2007, 09:46 AM
the first one helped some, im going to have to take off the throttle cover to get to it
Old 11-12-2007, 09:48 AM
I posted wrong link on second 1 srry about that let me edit it there hope that helps http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Rebuilt Motor
Old 11-12-2007, 09:53 AM
that one helped allot
Old 11-12-2007, 12:29 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
The TPS is not overly expensive, but it's very easy to test with a multimeter. I'd suggest you test it for linearity prior to just replacing it.
You should also check for vacuum leaks, verify the Idle Air Control is doing it's job, and that there isn't a build up of carbon on the throttle plate preventing it from closing completely.
-Rod
Old 11-17-2007, 02:42 PM
UsedtobeSmart UsedtobeSmart is offline
The Duratec wasn't in the Taurus (if it was even in production) till 1996.
Any luck getting the problem solved?
