Old 11-11-2007, 03:39 PM
snoles snoles is offline
Z71 fuel gauge
I have a 1998 Z71 with 150 thousand miles. Over the weekend my fuel gauge started jumping very fast almost like a fluttering or vibration. Also when I first start the vehicle the gauge pegs all the way down to the right in which it has never done that before. I just recently changed the fuel pump and that seems to be operated very well. Any suggestions would be greatly appreciated.
Thank you-
Old 11-12-2007, 09:43 AM
rjeffery rjeffery is offline
Re: Z71 fuel gauge
It sounds like you got a bad pump/sending unit, or it was damaged on install. What brand pump did you use?
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 11-12-2007, 12:18 PM
Re: Z71 fuel gauge
I used a Bosch that has a life time warrenty
Old 11-12-2007, 02:44 PM
Re: Z71 fuel gauge
If I were you I would try to get my money back on the Bosch and buy an OEM pump. From what i've heard from other people's experiences with aftermarket pumps is that they are junk.
If you can't get your money back, you could try another Bosch. It just takes a lot of time and effort to replace these pumps, and it's probably not something you want to keep doing.
Old 11-12-2007, 05:29 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Re: Z71 fuel gauge
I have never had to replace the pump but it sounds like a sending unit problem...was there a new sending unit on the pump?
Old 11-12-2007, 06:02 PM
Re: Z71 fuel gauge
It is a sending unit problem. In my previous posts, I was referring to the complete fuel pump/sending unit assembly.
Old 11-12-2007, 07:41 PM
Sonny01's Avatar
Re: Z71 fuel gauge
Yes...I understand what you said but because the original poster said this:I just recently changed the fuel pump and that seems to be operated very well. I was wondering if he kept the original sending unit.
