Old 11-11-2007, 02:06 PM
macdhb macdhb is offline
Lift Kit
Greetings All
I have 2005 Silvy 4x4. Love the truck and need to make it bigger.
Thinking Pro Comp 6" lift with 35x12.50x17 tires.
Will the tires I want fit on the stock aluminum wheels and
What is your opinion on the lift kit
Pros and Cons
Other lift kits???
Any suggestions?
Old 11-11-2007, 03:07 PM
01silverado03z400's Avatar
01silverado03z400 01silverado03z400 is offline
Send a message via MSN to 01silverado03z400
Re: Lift Kit
The pro comp lift is a good kit for the nbs trucks. I was thinking of doing the same on mine until i bought my 83 sierra and now all my money is going into it. Are you looking at the knuckle kit or the full drop kit? If you want to run factory rims then you have to get the full drop kit. It is a bit more expensive but much worth it because it drops your differential down the full 6" therefore giving you better cv angles and a nicer ride.
Yes the tires will fit on your factory rims but you have to look around for a place to put them on because not everyone is willing to put a 12.5" wide tire on a 7" rim but it can be done. I ran 315/75/16 which is 35x12.5x16 on my factory rims for sometime and it was fine. I'm actually putting them back on my stock rims for the winter.
The best lift out there for the nbs trucks is probably cognito which is a 7-9" lift. It is very pricey tho.
NEW - 2004 Chevrolet Silverado 5.3L RCSB Z71 Hooker AeroChamber - Black Bear Tune - Welds - 33" Mickey Thompsons
01 Silverado 4.8L ECSB 4x4 True Flow - Magnaflow - Black Bear Tune - 35" BFG A/T - 4.56 Auburn SOLD
83 Sierra RCSB 2wd 350 Under construction
Old 11-11-2007, 07:02 PM
bigbadram51 bigbadram51 is offline
Re: Lift Kit
WERD UP on the Cognito.... Def. more spendy but worth every penny... One thing to consider with lifts... Full drops do drop the front diff the full amount (Cognito and Fabtech (i think) do as well. But with full drops they dont keep alignment as well as knuckle kits... I have had my cognito on for almost 2 years now and still tracks straight. And I believe knuckle kits are stronger. When I replace my half ton with a 3/4 ton another Cognito is going on.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 12-01-2007, 09:15 PM
judgeman6970 judgeman6970 is offline
Re: Lift Kit
just my opinion...but if you're spending money on a lift kit & 35's....i would buy wider wheels with the correct backspacing....
