Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-11-2007, 10:06 AM
BigNakedBob32 BigNakedBob32 is offline
Starter cranks while key in run position
This is on an 89 iroc 5.7 auto, When the key is turned to the run position it starts to cranks and will just continue to do so until turn back to the off position. I already swapped the ignition switch out with a spare that i have and it still does the same thing. I was wondering if anybody has had this problem or know what it might be.
Old 11-11-2007, 12:44 PM
Morley Morley is offline
Re: Starter cranks while key in run position
Starter solenoid is stuck/contacts welded together.
Old 11-15-2007, 06:52 PM
Nope, any other ideas?
Old 11-16-2007, 12:11 AM
Either the switch is misadjusted or you have a serious short.
Old 11-16-2007, 09:32 AM
I'm leaning towards short because the wiring is just screwed. I have all the wiring diagrams so i guess i'll just be running through making everything right.
Old 11-16-2007, 12:44 PM
Thumbs up Re: Starter cranks while key in run position
a little rewiring and everything works
Old 11-17-2007, 11:13 AM
Its kind of hard to help someone with their problems when they leave little tid bits like this out of their original post...glad you got it fixed.
