Old 11-11-2007, 08:28 AM
lectrc lectrc is offline
Steering Problem
I have a 2000 Lesabre and after it sets over night when I start it it won't turn to the left. It will turn right fine but it won't turn left until after I turn it to the right a few times and the car warms up. Even then as it turns to the left I can feel a little catch as I turn the wheel to the left. Any suggestions?
Old 11-11-2007, 09:11 AM
maxwedge maxwedge is offline
A990 racer
Re: Steering Problem
Welcome to AF, possible something binding in the steering or suspension, more likely the P/S rack is bad.
Old 11-11-2007, 09:36 AM
If something was binding why would it go away after warming up?
Old 11-11-2007, 01:55 PM
A990 racer
Attempts to turn the wheel can temporarily loosen a ball /socket component, as I said the rack is a more likely culprit. Disconnect the tie rod ends when cold and turn the wheels lt to rt to isolate the condition, some attempt to mechanically diagnose this has to be done.
Old 11-11-2007, 02:32 PM
inafogg inafogg is offline
sounds like the spool valve seals but i have'nt see this in awhile its usually associated with the older gm modles 80's - earlly 90's
