Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 11-11-2007, 01:37 AM
utmpudge utmpudge is offline
Audio Help
I am planning on getting 2 10" alpine type R subs for my 02' cav., what size amplifier should I get? I'm not real good with the whole audio aspect so some help and suggestions would be appreciated.
Old 11-12-2007, 12:11 PM
sarkazm sarkazm is offline
Re: Audio Help
In my opinion, Jl Audio makes the best amps.
I think its the slash series. THey work with low voltage, and they put out the same power regardless of the voltage, I think down to 9. They make a 250/1 JL audio amp that will easliy push 2 12s if you decided to upgrade. I am running punch amps and I totally love them.
Old 11-13-2007, 01:47 AM
Jake44003 Jake44003 is offline
Re: Audio Help
I would say no no on the Alpine man. Check this out. JWDesinz in alliquipa pa hit a 178 with 2 SPLW15's and BXI 1606D. Check out the SPLW12's if 12's are what you want. Either way they should be wired ( each woofer ) series the coils, paraleled into the amp. This will create between a 1.3 - 2.0 ohm load and this amp will run strong for a long long time without heat issues.
Hope this helps,
Jake - www.StompAudio.com loyal customer
ps. they also have a new forum. http://forum.stompaudio.com. When you check them out stop by and say hi.
Old 11-13-2007, 07:40 PM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
Re: Audio Help
those jl amps get the same sound no matter the input voltage by charging caps to maintain voltage going to the amp. they sound nice though.. good and warm - nice dampening
Old 11-19-2007, 12:26 PM
Re: Audio Help
alright i will look into it, thanks for the suggestions and one more question do you think a 10 or 12 would sound better in my car? i don't really want any rattle i just want a good clean thump so what are yall's opinions
Old 11-19-2007, 07:25 PM
Re: Audio Help
in my opinion... ( i have two twelves) for sound qaulity, 10's do much better with the right amp.
you get alot tighter cleaner bass, whereass with a 12 you get more "thump"
Old 11-19-2007, 11:09 PM
Re: Audio Help
ok so if i have 2 10's will a 500 watt amp do the job or will i need bigger and will 2 12's fit ok in the cav's trunk and if so what amp makes it sound the best and i'm sorry for bein such a newb at this stuff
Old 11-19-2007, 11:41 PM
millrtime millrtime is offline
Re: Audio Help
depends how many watts r.m.s. the subs are rated at. and as for your system not rattling....good luck with that. you have a cavalier and ANYTHING that is somewhat loose will rattle. hell my back deck rattles with my stock speakers in it if i turn it up high enough. get some dynomat and some new weatherstripping and you might be able to avoid rattling. i would go with a good powerful 10, cuz anything more than that will be way to loud for a cavalier. my friend had a 15" solobaric and a 800 watt amp in an integra and bass is all you could hear.
