| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
My paint just won't dry
I've switched from Tamiya rattle can lacquer to dupont basecoat and even after I put it in the dehydrator the damn thing stays tacky
I'm using a painters pride reducer that my buddy at the paint store told me to get. I don't know if it only applies to real cars or what?! I've read in the threads about getting something called UR40 to use as a reducer. I like the results with the dupont basecoat...... what do you guys think? |
Re: My paint just won't dry
Rule of thumb, use the paint company's original thinner. That way you won't have incompatiblilty problems. Tamiya paint dry for me within 12 hours in my dehydrator, even if its a running wet coat.
Please read the following linked articals before posting a question. Once you have and still have questions, try to post your questions clearly. This will make a lot of people's blood pressure drop back to normal, including mine. NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST AF Car Modeling Tutorial, How-To and Product Review Depository AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0 And finally,I wish you all happy modeling
yeah, i've had really good luck with tamiya paints too, the problem is i had to match an original color of a 71' thunderbird and i can't do that with tamiya.
MCW is great but I don't have the time or patience to wait to get it ordered. MCW only takes written orders, no phone orders which is a pain in the a** Though I do like MCW paints alot~ I'm gonna leave it in the dehydrator tonight and see what happens. Good advice Cyber, i appreciat it man |
Something is very wrong alright. I mix one part Dupont Chromabase with one part lacquer thinner or BASF UR40 (as recommended by my automotive paint store) and it dries to the touch in about five minutes. Decanted Tamiya takes much longer to dry and always stays a bit soft.
Chromabase is way too thick to be sprayed un-thinned. By the way, there are five Painters Pride reducers, and even more thinners. You can download their PDF at www.painterspride.com/pp/productcatalog.pdf and check it out. Seems like several of the thinners and reducers would work with Chromabase - or at least not cause drying problems. It's possible you have the wrong one. I think we'll be curious to learn what works for you. Diddy Last edited by Didymus; 11-12-2007 at 08:08 PM. |
Diddy.....I have my Chromaclear mixture down pretty well, it's the dupont basecoat that I'm new to using that is giving me a problem. I mixed it with a product called "painters pride basecoat reducer"
I made a fatal error in regards to metallics too, thank God I only messed up the hood. I used Tamiya compound prior to clearing it and it rubbed down to the silver. I obviously didn't read the threads until after i screwed it up......I stripped it and started over. Diddy, what can you tell me about dupont basecoat procedures |
There seems to have been a mis-reading of Sixx's OP. His drying problem is with Dupont, not Tamiya. Diddy Last edited by Didymus; 11-12-2007 at 08:10 PM. |
Dupont Chromabase, mixed 1-1 with either lacquer thinner or UR40, should dry very fast and very hard. Sorry, but I don't know anything about metallics. I only spray solid colors. Diddy |
thanks Didy for the advice, i'm gonna try mixing it with the laquer thinner and let you know how it comes out! I didn't know that the clear and basecoat were to be mixed the same
I use Model Master Buffing Metallizer as a "thickness standard." It's very thin stuff, but it sprays beautifully. I think most orange peel problems are caused by paint that's too thick. When in doubt, I add more thinner! BUT... I've been told by two automotive paint shop owners that two-part urethane clear coat "breaks down" when you thin it... at all. Has that been your experience? Do you use Dupont two-part clear? What ratio of clear coat to hardener to thinner do you use? Diddy |
Right on to the blues.........fat possum records, R.L burnside, a little Junior Kimbrough..........I can dig it
yeah, I'm using Dupont 2 part clear, mixed 4:1 clear to hardner and I thin it about 200% the clear is hardening allright, it's the damn base that i'm mixing 1:1 color to reducer I'm gonna mess around with it a little more to get it mixed right! i'll catch you when i get it right, Diddy........ |
Assuming you're using one-part Chromabase (no separate hardener) with either lacquer thinner or reducer for automotive urethanes, one-to-one color to thinner/reducer should do the trick. If it doesn't, there's something other than mixture going on. Diddy |
