Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 11-10-2007, 07:08 PM
90na300zx 90na300zx is offline
Send a message via AIM to 90na300zx
Bleeding brakes tomorrow, 02 galant. HELP
I plan on doing the brakes on my gf's 02 galant tomorrow. Is the brake install pretty straight forward? The only thing I am really worried about is if I have to bleed the brakes if I don't get any resistance in the brake pedal. Anyone know how it is done in these cars? Thanks for the help in advance!
Old 11-10-2007, 08:16 PM
akrenzer akrenzer is offline
Re: Bleeding brakes tomorrow, 02 galant. HELP
If you're only doing the brakes,not the calipers,there shouldn't be a need to bleed the brakes,only if you introduce air to the system,
Old 02-04-2008, 10:40 AM
dragomistu dragomistu is offline
If you need to bleed the brake, you'll need more brake fluids, tools for bleeding valves.
notes: make sure to add more brake fluid because if it's empty, air will get into master cylinder.
1. Have person #1 pump the brake, then hold down the pedal.
2. While person #1 holding down the brake pedal, person #2 open the bleeding valve on the caliper to let brake fluid & air out.
3. Person #1 will not let go of brake pedal until person # 2 tight the bleeding valve.
Do that on all 4 sides.
