Old 11-10-2007, 04:45 PM
jowilker jowilker is offline
Engine shutter
97 3.0L Vulcan.
I am having engine shutter when there becomes a little strain like going up a hill. As soon as things level out or the little extra umpth isn't needed, it clears up.
I had codes pulled and the lower stream front bank ox sensor showed needing replacing. Somehow I don't think the ox sensor is causing this.
Any ideas where to start looking?
John
In the cool still quiet hours of night, you can hear chevies rusting away.
Old 11-10-2007, 05:17 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Engine shutter
Consider if this started to occur just after filling up with gas. If so, check with the station to see if others have complained about pinging after filling up at their station.
Try adding a bottle of fuel injector cleaner to your fuel tank if you haven't done so recently.
Also, you might have an EGR system that isn't functioning properly. You can clean the EGR valve and passages and see if that helps.
If none of these seem to have an effect, then you may want to pick up a can of SeaFoam and follow the instructions on the can to perform a cylinder decarbonization procedure on your car.
-Rod
Old 11-10-2007, 05:29 PM
Re: Engine shutter
Rod, Do you think a cat. converter could be playing a role in this. The engine was moved to this car that had a badly blown head gasket and a lot of coolant was pumped into the exhaust system.
I can shift out of OD and it stops with a little increase in rpms.
John
Old 11-10-2007, 06:36 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Engine shutter
How long since last tune up? Sounds like you may be having a plug break down under load. The O2 sensors will definately be affected if there was antifreeze pumping into the exhaust. It might not cause the problem you are describing though. Post the EXACT code back and we can help on the diagnostics more.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-10-2007, 06:50 PM
Re: Engine shutter
Plugs and wires were changed when the engine was swapped in with 105,000 or so on the originals. Less than 5,000 on the current ones. I have swapped ox sensors around and will swap again with the other car.
I had the code read at Advance Auto and all he would say was First bank second sensor. sorry
John
Old 11-10-2007, 07:22 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Engine shutter
How long since transmission has been serviced. It is possible the torque converter is starting to slip a little under load.
Old 11-10-2007, 07:25 PM
Re: Engine shutter
Transmission total rebuild about 80 miles ago.
Old 11-12-2007, 07:23 PM
Re: Engine shutter
Took the car out on a little road trip today, about 40 miles each way. Noticed the shutter most at below 2000 rpms, heavy at about 1500. Also noticed some on take off from stop. Tried once from an incline stop light footing it, smooth as a spanked babys butt. Normal takeoff had it for the first couple seconds.
More feedback please.
John
Old 11-12-2007, 09:57 PM
shorod's Avatar
SHO No Mo
Re: Engine shutter
Have you cleaned the EGR valve and passages or performed the cylinder decarb as suggested in post #2 above?
-Rod
Old 11-12-2007, 10:34 PM
Re: Engine shutter
Rod I have not. Is there an article for proper cleaning of the egr?
Which FI cleaner does this site prefer?
