Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 11-10-2007, 01:19 PM
kyleholt11 kyleholt11 is offline
Tranny Question???
Could I take a torque converter off of a TH-350c and put it on a 700R4?
Old 11-10-2007, 01:28 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Tranny Question???
No.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-11-2007, 03:14 PM
Why wouldnt it work?
Old 11-11-2007, 03:30 PM
silicon212's Avatar
Confoundingly Lucid
Ever tried to bolt a Ford Windsor cylinder head onto a small block Chevy? No?
It's not designed to. The TH350 uses SAE (English) measurements - inches etc. The TH700R4 uses metric measurements. The front pumps are different, spline count is different, hub diameter is different.
You can use a torque converter for a TH400 on a TH350 and vice versa - as they are the same. You can use a TH2004R converter with its 27-spline input shaft on an early TH700R4, through mid 1984, but from mid-'84 to today the TH700R4/4L60/4L60E (non-PWM) uses a converter for a 30-spline input shaft.
Old 05-10-2010, 02:41 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Yeah, And beside that, the input shafts iare a totally different...........just look at them.
