Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-10-2007, 12:19 PM
Sunbound85 Sunbound85 is offline
body mounts
I am currently getting my 1983 chevy caprice painted.
I then realised that the front body mounts were completely rotted and had fallen out, the bolts themselves are rusted up and unusable. The entire front end of the car is out of alignment with the frame (The frame is straight and solid) when I drive around a corner, I can hear the fan hitting against the shroud as thebody shifts on its rotten front mounts. Is there a good aftermarket source for a set urethane or even rubber mounts for the 1980's box style chevy?
energy suspension only supplies mounts for 66-70 and 90-96 model years. Would any of these mounts work on an '83?
Any advice appreciated !
Old 11-10-2007, 01:26 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: body mounts
The '90-'96 will. The '90 is a boxy like yours.
The mounts were the same from '77-'96.
There should be 8 of them on your car - 4 under the passenger compartment and 2 on each end.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-11-2007, 09:21 PM
Re: body mounts
Thanks silicon212,
Now the body work can be done properly, no point painting a sagging body.
See link to mounts I found on Summit Racing... $93.39, comes as a full set.
http://store.summitracing.com/partde...5&autoview=sku
Old 11-12-2007, 09:06 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: body mounts
Note when purchasing: Urethane mounts will last practically forever but will take away from the soft ride a little bit, where rubber mounts will last a good 20+ years but will also help to absorb road vibration better than urethane will.
Old 11-14-2007, 11:20 PM
Blue Bowtie's Avatar
Registered Offender
Re: body mounts
The later factory mounts are a fairly high durometer rated rubber, not much softer than many urethanes. The factory bushings are no bargain, either, at about $11 apiece for various thicknesses (and there are several thicknesses).
Old 11-15-2007, 10:52 AM
Re: body mounts
I live in The Bahamas and have had no luck obtaining the OEM rubber bushings from both The local GM dealer and other parts stores such as NAPA, although NAPA does have the part listed. So barring a trip stateside, I have to source the bushings over the internet, if anyone else knows somewhere else to find the original rubber bushings, please let me know.
Again, Thanks for all the advice...
next item to replace will be those sagging front springs... the car looks like its in a perpetual state of a nose diving stop.
