| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
Dyno?
Many people have told me, not to even try to dyno my car, or be too hard on it...well a short while ago, i got on a dyno, and pushed it. i was expecting very less then what i got.
117 HP 133 LB-FT At the wheels it was a nice run, all goin good, sounded nice at WOT at around 70-80 All i have is a short ram intake, which actually kind of sucks hot air off the exhaust. I plan to fix that issue. And instead of a cat, a test pipe, with two old torn mufflers, rapped in muffler bandages. and of course, a fresh oil change Maybe more mods? Not sure yet.
2009 Pontiac G6 2.4L L4 2007 Buick Lucerne CXL 3.8L V6 2007 Chevrolet TrailBlazer LT 4.2L L6 1993 Oldsmobile Cutlass Supreme SL 3.1L V6 |
Re: Dyno?
That seems low.... what engine/trans is in your car ??
1999 Grand Am SS 3.4 OHV
Re: Dyno?
It's the 3.1L V6 Vin T paired up with the 4T60-E Tranny
factory spec is 140 HP, 185 FT-LB to the crank, i believe
Re: Dyno?
140 HP - 20% = 115.2 (wheel HP), so you are close to factory spec.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Re: Dyno?
So my GA SE is 234HP at the wheels, do I add 20% to make it crank HP reading.......
... 280.8hp at the crank
Re: Dyno?
Yes, 20-25% is a good number, either added or subtracted, on an auto trans car.
Re: Dyno?
so infact, im over factory spec, so the test pipe and intake i guess did do something.
just curious, i remember hearing somewhere that i can take the upper and lower intake manifolds off of the 3.4L DOHC and they will fit on my 3.1L V6, and in turn i would get some gains off of that, but im not too sure about the fuel injectors, vaccuum lines, etc. any words of advice if i was to partake in this daring move?
Re: Dyno?
OOopS!
That 234 was wrong, thats the torq my 3.4 has, its only 224hp, so that like 269 at the crank ![]() This link might explain what will fit your 3.1.
