Old 11-09-2007, 10:41 PM
nelzone17 nelzone17 is offline
1999 windstar lx rough idle
My van has recently started to idle rough to the point it dies.It dosen't do it all the time, mostly after it has ran a while. I noticed something odd when it was running bad the other day. The needle on the fuel gauge was moving up and down. I know this can't be normal. The cel is on, in fact it has been on. I get codes 171 174.Any help would be appreciated
Old 11-10-2007, 09:03 AM
wiswind wiswind is offline
Re: 1999 windstar lx rough idle
The codes that you list are an indication of a lean conditon on both banks of cylinders.
Have you done the isolator bolt TSB?
The top sticky post provides a lot of information about it.
That is the FIRST thing that I would think of to advise.
If you already have the improved isolator bolts, the most likely cause is still a vaccum leak.
Those can be difficult to track down.
Also, are all the routine tune-up items up to date?.....spark plugs, spark plug wires, fuel filter, air filter, etc
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
