Security Light
I'm not REALLY concerned about it but my security light comes on once in awhile ( about 1/20 times) that I start the car and stays on until I turn it off. Is this something to worry about or to pay to get checked out?
Re: Security Light
this happens to me too...nothing to worry about i haven't been stranded anywhere yet.
Re: Security Light
YET is the key word.
![]() The light on indicates thiers a proeblem with the passlock system. Have you tried leaving the key "on" for a minute or two before you start the car ? That might make it go out. Other things that might make the security light illuminate would be to much weight on your key chain, which keeps the contacts inside the lock cylinder from making proper contact. Could also be your ignition switch or the lock cylinder going out. Might also try the relearn proceedure and see if that makes it go out for good. Here is that...... Quote:
1999 Grand Am SS 3.4 OHV
Re: Security Light
on my moms expedition the securtiy light came on sometimes and when it did the car wouldnt start. It had something to do with the remote starter, which i have on my car as well.
Re: Security Light
I just had a bypass put on the passlock system for my remote started AND I also have a pretty heavy keychain. I would have never thought of that one.
Maybe I should bring it back to the guys who put it in and see if they'll take a look at it for anything that might be loose or whatever. |
Re: Security Light
Yeah thiers actualy a GM TSB on heavy key chains causing passlock issues.
My GA SE used to do it everytime my wife drove it, then I'd get in and have no problems. She removed the excess junk from her keychain and the lights not been on since. But since you just had the remote starter installed I'd have them check it out. If somethings loose it'll cause some issues with the light coming on. Good Luck
Re: Security Light
Yep, do as stated above. Unfortunately there are many installers that either use crappy bypasses or their method of install bad. When that light comes on while you drive means that the computer is going into fail-enable mode. It's not seeing the proper connections inside the ignition switch or for some reason just isn't getting the right code after it successfully starts. It WILL get you stranded sometime if not corrected or bypassed.
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
