Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-09-2007, 08:45 PM
evildragon evildragon is offline
heat, need heat!
Yea, winter is coming, and today I needed to blast my heat. To my surprise, when I turn the dial to heat, NOTHING comes out of the top vents, only the bottom vents.
I want them to come out of the top vents, especially my hands, they get very cold.
Is there no way to get heat out of the top vents?
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 11-12-2007, 08:36 PM
Re: heat, need heat!
It should be noted I don't have the manual.
L99 Engine
Old 11-12-2007, 10:28 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Controls can be somewhat odd in older cars if you're not used to them... if you want heat you must turn the slider (or knob) from cold to hot. Then to get it to blow on the floor, slide the other slider (or knob) to "HEAT"; to get it to blow out of the upper/middle vents got to "VENT" and to get the heat to blow out of the defrost at the windshield, got to "DEF."
This is all second nature to me because it's what I grew up with and don't really drive any vehicles newer than 1989 which still had controls like this.
Old 11-12-2007, 11:19 PM
So Vent can also be heat? I thought that wouldn't give the same heat as "Heat" itself.
Weird, thanks for the tip.
Btw, what's "B/L"?
L99 Engine
Old 11-12-2007, 11:42 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Yes - if you select Vent and put the heat slider on high, two things happen - first, you get the warm air from the A/C vents and second, you get fresh outside air.
Works well, 'tis how I do it.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-13-2007, 08:00 AM
PeteA216's Avatar
In terms of Air Conditioning: MAX = front vents, NORM = front/floor blend, Bi-Lev or "B/L" is the floor vents. At least thats how I think I remember it.
Old 11-13-2007, 08:40 AM
I thought Norm mixed AC with outside air? That's what I was told by a mechanic one time.
L99 Engine
Old 11-13-2007, 09:05 AM
PeteA216's Avatar
You're probably right, I was never 100% sure about the A/C controls, I just know that "B/L" or "Bi-Lev" aims it towards the floor. In terms of the inside/outside air mixture I have no idea. I know in new cars/truck you hit a button if you want it to recirculate inside air, or take fresh air in. I'm almost sure my '84 takes outside air in full time with no recirculation. I haven't ever seen any way for the air to not come from the outside.
Old 11-13-2007, 09:38 AM
GreyGoose006 GreyGoose006 is offline
no no no no no...
at least on my 84, heat is floor,
vent is upper vents
defrost is windshield
bi-lev is all of the above
ac dehumidifies the air.
max ac has the compressor on full time
Old 11-13-2007, 10:33 AM
silicon212's Avatar
Confoundingly Lucid
Heat is floor,
vent is the main vents,
defrost is windshield*,
bi-level is main and windshield (no floor, but lap vents are included).
Max runs the fan in high mode, which causes the compressor to run longer - but not continuously.
* on my car, defrost mode turns on the compressor and forces cold air through the vents as opposed to warm air. As GreyGoose noted above, cold air dehumidifies and removes the fog from the window sooner. It's not great to have that cold air coming off the windshield onto driver when it's cold outside, but here in south central Arizona, there's not too many days like that.
Old 11-13-2007, 11:42 AM
PeteA216's Avatar
Originally Posted by GreyGoose006
no no no no no...
vent is upper vents
Lol, thats what I said... my confusion was cleared up by silicon in terms of the Air Conditioning controls. This is probably why they switched over to the simple directions they have on cars now: A button for A/C on and off, a button for fresh air or recirculation, an air temperature control, a fan speed control, and vent placement control. I really like the dual driver/passenger climate controls available now.
Old 11-14-2007, 07:39 PM
yeah, i wasnt arguing with you.
on mine, bi-lev is floor, lap, and main vents.
dont know about yall tho
