Old 11-09-2007, 08:41 PM
fuct33 fuct33 is offline
Arrow egr valve prob
I had a problem earlier and believe that it was due to the egr valve I took it off now what am I cleaning to free if its stuck and how can I tell if its stuck can I use carb or brake cleaner to flush it out its off 94 s10 4.3 cpi 4x4
Old 11-10-2007, 04:08 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: egr valve prob
They say not to use Carb or Brake cleaner. I think they make a special cleaner, not sure. What you need to be concerned about is the small passage ways, which you can clean with a drill bit (by hand) and a screw driver and a wire brush on the other parts.
Old 11-10-2007, 06:45 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: egr valve prob
After you remove the EGR valve, check to see if the pintle (little plug valve) is partially open, if so, gently push it full open with a pencil then quickly pull the pencil back so the inner spring can push the pintle back out. Sometimes this has to be done several times because the pintle stem can have a thin layer of carbon. If it's stuck fully open then use compressed air on the EGR inlet port to blow the pentle shut then use the pencil trick until it shuts by itself easily. Check with your auto parts store for a screened EGR valve gasket or buy a stainless faucet screen and glue to a regular gasket over the inlet port hole (thanks Jim of Phoenix) to keep loose chunks of carbon from holding the pintle open.
