Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-09-2007, 08:37 PM
lonestar98 lonestar98 is offline
Smile spider injector
I just replaced the spider injector on my 98 tahoe and 3days later i get a sucking sound from somewhere it sounds like its coming from under my dash
you get under the hood you dont hear anything thanx (great site )
Old 11-10-2007, 05:16 PM
WHATDIDYOUBREAKNOW WHATDIDYOUBREAKNOW is offline
Re: spider injector
Lose vacuum hose or leak in brake booster(does sound change when you push on break pedal?)
Old 11-11-2007, 09:28 AM
Re: spider injector
the sound dont change even when you give it gas or the brake
i did noticed when i turn the key on i can hear the fuel pump buzz and
that sound from the motor its like a rushing sound of fuel or pressure.
Old 11-15-2007, 03:41 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: spider injector
If the HVAC stuff is vacuum operated, you probably have a break in the line. Find where it goes through the firewall and disconnect it, if it goes away then, start digging around under the dash 'till you find it.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 11-19-2007, 08:35 PM
Re: spider injector
I found out what the noise was it was the fuel line touching the firewall
man the sound was loud cant believe it amplified it that much well many
thanx
