Old 11-09-2007, 04:04 PM
ss008 ss008 is offline
ECM code 43 thrown
Just picked up my 94 Chevy S10 V6 2-wheel drive OBD1 and got a ECM code 43.
no intial problem so far except the SES light (ofcoarse)
what should i check? how do I fix?
Thanks
Old 11-09-2007, 05:40 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: ECM code 43 thrown
Welcome to AF
It is a knock sensor code.
But could be caused by other things like wiring or pcm.
Look over wiring and see if knock sensor/sensors are pluged in.
Does the engine have any knocks or spark pining?
Clear code and see if it comes back.
Single or dual knock sensors and does it have electronic spark control?
Can you get a voltage reading on knock sensor circuit?
Do you have a scanner to check the knock signal in pcm.?
MT
Old 11-09-2007, 08:52 PM
i just checked and the knock sensors are plugged in.
I cleared the code and it came right back.
I have dual knock sensors w/ESC
I will get a voltage reading on the knock sensor circuit tonight.
In the mean time, what if the voltage reading is low? And whats the worst case senerio for this kinda problem.
Thanks.....it's my first truck ( and domestic automobile )
Old 11-10-2007, 10:29 AM
MT-2500's Avatar
AF - Advisor
Start with a voltage reading with key on and gear shift in dive.
MT
MT
Old 11-10-2007, 11:00 AM
put a new battery in yesterday night.
the voltage reading is around 10.
and jumps upto 14.5 when the engine is on.
also when driving with headlights, the voltage drops to 14
same with when turn signals are on, it toggles from 13.5 to 14.
Old 11-10-2007, 11:04 AM
MT-2500's Avatar
AF - Advisor
Voltage reading on knock sensor circuit?
MT
Old 11-10-2007, 11:09 AM
i haven't taken those yet. gotta head to the auto parts store and get a voltage reader
Old 11-10-2007, 11:18 AM
MT-2500's Avatar
AF - Advisor
When checking voltage on a computer circuit always use a good high end volt meter with low impedance.
MT
