Old 11-09-2007, 07:49 AM
mistermoonpie mistermoonpie is offline
Oil pressure drop at Idle
Hey guys. I noticed the other day that sometimes when I come up to a red light and put the car in neutral, the Rpms drop down to around 500-600 and the oil pressure drops way down. If I rev a little bit the oil pressure reading goes back up, and it goes back to normal once I start driving again. (no CEL in case that helps anyone with diagnosis)
'97 3000GT SL
-Short Ram Intake
-Test Pipe
-Custom Exhaust
-17" Infinity Rims
-Infinity Kappa Component Sound System
-Kenwood Double Din Headunit
Old 11-09-2007, 07:52 AM
AutostradaVR4 AutostradaVR4 is offline
Re: Oil pressure drop at Idle
thats pretty normal, especially if your using the stock gauge. the stocker is garbage.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 11-09-2007, 08:31 AM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Is there a walkthrough on changing the stock guage? Mine is completely dead, so i just look for the oil light, but id rather fix my guage.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 11-09-2007, 09:10 AM
Ok so I don't have like an oil leak or anything like that? I'd heard that the stock gagues were POS's, but I just wanted to make sure
'97 3000GT SL
-Short Ram Intake
-Test Pipe
-Custom Exhaust
-17" Infinity Rims
Old 11-09-2007, 09:21 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
The light is for oil pressure, not oil level. Of course no oil would mean no oil pressure.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-09-2007, 09:29 AM
new2mitsu new2mitsu is offline
my car is the same way, but as soon as im at any kinda running rpms(i.e. 1.6-2.2k +) the oil pressure is right where it should be
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 11-09-2007, 10:01 AM
liquidPunk's Avatar
exactly< i kinda use it as a fail safe, but i just tend to check the oil on an obsessive compulsive level. but anybody seen a how to on fixing this problem?
-More to come-
Old 11-09-2007, 10:05 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Well there may not be a problem, it could be the garbage stock gauge giving you bad readings. Or there could be a lot of wear on the bearings in your engine which would cause low oil pressure at idle. Or your oil pump could have excessive clearances in it from normal wear so it can't give enough pressure at idle.
So, start with the gauge or there are mechanical oil pressure testers you can use.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 11-09-2007, 10:09 AM
blu3kgt blu3kgt is offline
i agree it pretty normal....but you cant use the oil pressure gauge to determine an oil leak anyways.... just look under the car for leaks or place a card board under it and see...but if it doesn have leaks, it doesn't mean you dont have to check your oil either,check your oil regularly.... my car car has no oil leaks and no exhaust smoke of any sort.... but like after a few weeks i still have to add a little bit of oil...
97 3kgt sohc.... intake, custom exhaust, 3sx crank pulley, JVC head unit, pioneer speakers all around for highs and mids amped, 12"JBL power series sub....
Old 11-09-2007, 10:45 AM
hey twisted, thats a damn good time for the mods you have... im impressed, jus curious if you had ne fuel system upgrades at all, or how the hell you don't hit fuel cut like a mfer...
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 11-09-2007, 09:27 PM
Thanks, and that was on one of my worst launches that day (1.91, was hitting low 1.8's other runs). No fuel mods, stock pump/injectors, no controller, pump not hotwired. I've never once hit fuel cut, no knock from what i've deduced from datalogs of timing/02's, plus previous owner did the hybrid ecu swap when he had it and it never knocked at 15 psi. 02's even show room for more boost, though without knock being logged real time it's not worth it to try for me.
Why? Do you get fuel cut?
Old 11-10-2007, 12:04 PM
occasionaly, even at 14.5 if its colder tha normal...
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
