Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-08-2007, 10:38 PM
mike561 mike561 is offline
Electrical problem
This started after installed a power trunk release actuator, which works fine but now my left tail lights arent working right, the left turn signal wont flash and the light in the middle on the left side is bright as if the brake is pressed. the tail lamp fuse keeps blowing too. i did the trunk release install carefully and made sure i did not interrupt any other wiring. btw i plugged the trunk actuator to one of the aux inputs on the fuse box, i even tried unplugging it to see if it would do anything but the left tailights are still not working right. im very novice when it comes to electrical stuff...
2006 Chevy Cobalt LS
Old 11-09-2007, 05:40 PM
Re: Electrical problem
Edit - I seemed to have fixed the problem so everything is back to normal, but i notice the flashers blink randomly, sometimes fast and sometimes slow...
Old 11-09-2007, 06:51 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The fast/slow blink rate might have to do with a blown bulb, that's not fully blown - i.e., the filament is loose on one side, but makes random contact.
Replace the bulbs and see if that helps.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-09-2007, 08:04 PM
ohh ok, i did replace all the tailight bulbs with fresh new ones, maybe they werent put in all the way because the sockets are so gunked up with that bulb grease. has anyone found an effective way of cleaning all that gunk out also?
Old 11-10-2007, 03:45 AM
CD Smalley CD Smalley is offline
You want that gunk. It keeps things from corroding up in there.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
