Old 11-08-2007, 09:28 PM
gshowell1 gshowell1 is offline
Vavle Stem Seals 95 350 TBI
Hello all,
This is my first post and I wish to find out some information about why my truck is smoking so bad. Its been going on for months now and I have been told with my 350tbi with 180,000 miles that it is most likely the valve stem seals. The parts are only $17 for intake/exhaust seals but every shop in town wants atleast $500 to do the work.
My question to you experienced guys is, is this very complicated? This will be my first time doing this. I have a few knowledgable friends to help me with the process but I would just like to hear from the experienced guys what kind of job it is.
It's to my understanding ill need a valve stem tool to compress and remove the valves to get down to the seal to replace it. Since I only have to do this 16 times (8cylinder) it seems like it should go along smoothly and not be too time consuming. Anyways, im just looking for extra info/help on this job.
Any of your replys are greatly appreciated. Thanks
griffin
Old 11-08-2007, 09:36 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Vavle Stem Seals 95 350 TBI
Welcome to AF.
The stem seals are actually O-rings that are located just below the keepers on the valve spring retainers. The springs need to be removed but not the valves. This can be done with the heads on the engine, but is far easier if the heads are removed. In any case, do one at a time so that retainers don't get mixed between intake and exhaust as you may experience fatigue failure later down the road.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-09-2007, 09:36 AM
777stickman 777stickman is offline
Just got done doing the '78 Blazer. You'll need an air compressor and an adapter to pressurize the cylinder to keep the valve from dropping down when you pull the spring off. Pull all of the spark plugs and the rocker arms in the beginning. Do one valve at a time. I use a very compact spring compressor so I can use both hands to get the keepers out and in. Use a good magnet and a pick. Also use a plastic hammer to give each spring retainer a good pop to break the seal on the keepers before you try to compress the spring.
It is a time consuming job and on a scale from 1-10 I would rate it as around a 6 in difficulty.
Good luck.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
