96 5.7vortec misfire
I have a 1996 silverado with 5.7vortec. Engine code shows no.6 cylinder misfire. I have done a complete tune-up and the problem is still there. Under full throttle or when accelerating it seems to run great. With cruise set or when lugging engine it feels like a dead cylinder. What do you guys think-cam,crank sensor-head gasket-burnt valve? It uses no oil and has good oil pressure but it does have 230,000 miles on it. Thanks!
Re: 96 5.7vortec misfire
Sounds like weak compression. Check the cylinder with a compression gauge - also check adjacent cylinders.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
