Old 11-08-2007, 07:51 PM
Burtnette Burtnette is offline
Gas Mileage Question
Ok so I recently got my u-bend & resonator removed and ever since that my gas milage dropped from 19-20 (city) to about 16 (city) mpg. I expected it to drop but I didn't know it would drop that much. Also the guy couldn't get my o2 sensor off so I had the choice of getting a new one for $100 or waiting but if I waited he said something like it wouldn't sound good and my gas milage would be shitty. Turns out it's shitty anyway. So what I want to know is that is that much of a drop normal or is something wrong? Thanks in advance.
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
72mm TB w/ TB spacer
WizAired CAI
3" DP w/ Borla Pro XS mufflers
OLD:
1995 Dodge Stealth
Old 11-08-2007, 09:16 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Gas Milage Question
Are you sure it is not coincidental with the weather change? Normal to see a drop in mileage when it gets cooler due to the longer engine warmup time and time for the PCM module to switch to closed loop mode.
Why did you remove the resonator? A point often overlooked is the engine needs some exhaust back pressure to operate properly and efficiently. I don't recall losing any gas mileage with just a u-bend delete. Don't remember or care on the resonator delete since fuel economy is not a factor for me.
Also, what brand 02 sensor was used?
Timeslip 08/12/06
AF Community Guidelines
Old 11-08-2007, 09:32 PM
Oh hmm the weather might be it. Will my mpg go back up once it gets used to the warm weather though? Also I got the resonator removed for a few reasons: mine had a hole in it and he said it would be much cheaper to remove it than to replace it and i was a little short on cash, he said it would give my exhaust a nicer tone (which it definately did), and i've heard about people on here getting it done with no problems so I thought sure why not.
EDIT: And I have no clue what the brand of the o2 sensor was used.
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
WizAired CAI
OLD:
1995 Dodge Stealth
Old 11-09-2007, 10:15 PM
Anyone? I want to know if I have to go back to the exhaust shop (if it is the o2 sensor) and get it fixed cuz this 16 (now actually about 15) mpg just isn't cutting it.
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
WizAired CAI
OLD:
1995 Dodge Stealth
Old 11-10-2007, 05:43 AM
BNaylor's Avatar
Assuming you're referring to the post CAT convertor O2 sensor since you did a u-bend delete technically that O2 sensor should not affect your gas mileage. All it is supposed to do is monitor CAT convertor efficiency. But in your case if your mileage was normal or acceptable before these exhaust mods then you may have to look into it. With a mileage drop that high obviously something is not right.
Timeslip 08/12/06
Old 11-10-2007, 09:11 AM
bigphili bigphili is offline
Re: Gas Mileage Question
A safe thing to do is crawl up under there and make sure they didn't melt any wires welding anything, it's not uncommon.
