Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 11-08-2007, 07:25 PM
Fitztex40 Fitztex40 is offline
1996 villager van slipping while driving....
hi I was wondering if any one esle has this problem.........I have noticed all week now that when I drive my 96 villager----it seems to be slipping and making a sound underneath and the rpm gauge is going up and down to 3 & back down to 1. I wonder if I can just change the transmission fluid in it could it be the transmission going out? I feel that it is the transmission because the way it trys to jerk like it is having a time changing gears......any answers would be apprecitated........
Old 11-11-2007, 05:07 PM
dzus dzus is offline
Re: 1996 villager van slipping while driving....
A bad thottle postion sensor may be a possibility, it will definately effect the tranny shifting.
Old 11-11-2007, 05:34 PM
inafogg inafogg is offline
hello if the idle is rising to 3k & back while just sitting in drive i'd try to fix idle problem first.check for vacuum leaks ect.
Old 11-18-2007, 01:14 PM
ok I changed the trans filter and trans oil. I drove it for 11 miles and on the way back home It stated acting up again. After I parked it, I was going to drive to store and it would not go into reverse but will go into drive. THE Engine light came on now. Managed to drive it to autozone this morning and put on computer machine......the machine said
Definiton:
incorrect 1st gear ratio condition.
Explanation:
transmission in 1st gear and the ecm detected and incorrect gear ration.
Possible Causes:
1. poor connection at transmission
2. internal transmission problem
the question is -------DO I NEED TO REPLACE THE WHOLE TRANSMISSION? OR CAN IT JUST BE A SENSOR?
Old 11-18-2007, 09:15 PM
Angry Re: 1996 villager van slipping while driving....
Ok I put in the new thottle postion sensor and still no reverse or 1st gear. The engine light did go off but what is the problem now? NEW TRANSMISSION? Any help would be appreciated!
Old 11-20-2007, 09:28 AM
Van not going into reverse is something new after changing the fluid sounds like tranny rebuild time. A TPS shouldn't effect reverse gear.
Old 11-20-2007, 12:32 PM
YEP! that is where it is now.......between $1300.00-$2100.00. The guy said problem is clutch or gears or something like that.
