Old 11-08-2007, 02:51 PM
heatwave202 heatwave202 is offline
2000 blazer wiring question
Hello,
I have a 2000 Blazer without fog lamps, however the relay and fuse are present in the electrical panel. Does anyone know if the wiring is present where lamps could be hooked up, and if the wiring connector for the factory switch is present? Would save a lot of wiring, and make a neater installation if so. Thanks for any information.
Old 11-08-2007, 07:17 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: 2000 blazer wiring question
Do you know if it had fog lamps, but they were just pulled. It is a possibilty the wiring could very well be there, but to be honest I am not sure. On my '98 the dash cluster did not have a tach guage, but I found one at a recyclers and basiclly it was plug and play, wiring was there and everything. That being said, it could be there..
Old 11-09-2007, 02:43 PM
It does not have fog lamps, interior switch, or the cutouts on the lower air dam for them. I do know that the relay and fuse are in place in the appropriate locations in the underhood electrical panel. I just didn't know if the wiring harnesses were all the same for the vehicles where the stuff could be there and just not used or taped up. I might hook up a fox & hound and see if the wiring could be located in the harnesses.
