2000 Bonneville Running Terrible
Hello everyone, I'm a newbie. I have a problem. SES is now flashing, the moment it started flashing, it started running terrible. On accelleration there is this awful shudder, like driving over a washboard. Also, feels like a tractor pull sled is being towed, no power at all. My gas mileage has been cut in half, costing me roughly $20/day for 70-80 mile trip. Took it to autozone, can't remember exact codes, but the guy said I had multiple cylinder misfiring, a bad EGR Valve, and both O2 sensors were bad. So, I begain by changing out the plug wires (but not the plugs...I know, I know), I have also replaced the EGR Valve. No change whatsoever in the performance. Engine is the 3800 w/ 130,000 miles. What should I do next?
Re: 2000 Bonneville Running Terrible
Change the plugs and make sure they arent bosch.Obviously problem with o2 sensors and maybe your cat is problem which would explain your gas mileage and feel like pulling a tractor.Check o2 sensors and cat.
2000 bonn ssei 155000 klm 1997 dodge caravan 92000 klm |
No matter what codes they pull, AZ always says you need o2 sensors. The CEL flashing indicates a misfire condition exists. Changing the plugs and wires would be the first step. I don't understand why you'd replace the wires but not the plugs!!! If you still have the printout they give you, post the codes here and we'll help you decipher them accurately. I would also suggest changing the fuel filter and PCV valve. Unlike the old days, the PCV is an important part of a tune up, as it feeds the MAP sensor it's vacuum signal. A clogged PCV on a Vin-K 3800 can cause driveability issues. Also, when replacing the PCV, don't forget to take the o-ring off the old PCV valve and transfer it to the new one or you'll develop a terrible vacuum leak and whistling noise.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
