Old 11-08-2007, 12:36 PM
indyscott indyscott is offline
03 T&C steering
If I travel a distance of 50+ miles in one trip and if I turn the steering makes a horrendous noise...around town short distances it does not do anything though.
Also the sliding door does not automatically open if it is cold outside, the dealer seems not to know how to take are of either situation
Old 11-08-2007, 11:23 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 03 T&C steering
If it's a sqealing noise you may have a worn or loose pump drivebelt. If it's a moaning noise you may have a bad pump, contaminated fluid, pinched hose, clogged strainer (if there is one) etc. There's no magic bullet. It needs to be looked at by someone with some knowledge.
If you're a DIYer the first thing I would do is drain and replace the fluid. How? Either disconnect the hose at the pump leading from the reservoir or use a turkey baster and suck the reservoir dry 4 times, driving it between fills. Still squeals? Change the belt. Still squeals? Change the pump.
Never touched a powered side door but, basics are basics. Make sure the tracks and lock mechanism are clean and lubed. Beyond that it may need adjusting or the drive motor may be getting weak.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-10-2007, 05:51 PM
wayneo69 wayneo69 is offline
Re: 03 T&C steering
check fluid level if okay and is a BRIGHT red put a rack in it the sliding door dont work when its cold or just stopped working alot of the time the wires get pinched in the plastic chain at the bottom track with in 3 inches of where it pins to the door arm/hinge/roller (inside the plastic chain)
Old 11-10-2007, 05:52 PM
Re: 03 T&C steering
by the way find a new dealer
