Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-08-2007, 12:17 AM
deesandvees's Avatar
deesandvees deesandvees is offline
resetting odometer...
Well I got the 9C1 speedo for my '87 and before I put it in I want to reset the odometer to "0000000" (it's only fair I got a new motor, trani & rearend). Anybody know how to do this?
Old 11-08-2007, 09:49 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: resetting odometer...
Yep, when I got the 9C1 speedo for my '84 it read 160k when my car really had 84k, so I took apart the speedometer unit making careful notes to myself of how all the little parts went together until I got the odometer cylinder out. I rearragned the numbers to match the original odometer from my caprice right down to the tenth of a mile. It'd be even easier to go back to zero, but I wanted accuracy. I changed this the same time I changed the motor, so I can always look back to the original speedo to see what the mileage was at the time of the engine swap.
Old 11-08-2007, 10:29 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Just remember that if you ever sell the car, you need to bring up this fact to the buying party. Failure to do so is a felony in most, if not all, states.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-08-2007, 10:56 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Thanks for mentioning that. I was going to post something in lieu of the previous postings concerning the law(s) on this, but was looking for the exact wording of the law online, to post here. Many states have a provision on the back of the vehicle's title to state whether or not the odometer's reading is the original miles for that vehicle, or a separate document that needs to be filled out by the seller, and filed when the vehicle is registered.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 11-09-2007, 05:09 PM
So basically just start taking it apart and be careful huh? No special tools required? I'll probably videotape the whole process so I can make sure I can get it back together if it's as complicated as I anticipate.
Old 11-10-2007, 03:40 PM
WLD AL3ARAB WLD AL3ARAB is offline
Send a message via AIM to WLD AL3ARAB Send a message via Yahoo to WLD AL3ARAB
I did that to my 88 caprice and after 9 hours i finally got it to work perfectly.
But it is tricky so be careful. And another important thing is the guages needles are fixed in a certain way if you didn't put them back the way they were you won't get an accurate speed reading. ( Don't forget to put some grease in the moving parts ).
Good luck
Caprice Brougham 88
V8 305
Old 11-11-2007, 11:19 AM
PeteA216's Avatar
Heres a video I made real fast of how to take out the odometer digit cylinder on the original speedometer from my '84 Caprice:
Odometer Removal
Watch not to loose that spring clip lol. After the cylider is removed, you'll see how I sort of zoom in on the back where a plastic piece holds onto little metal tabs. Once you've changed the odometer reading to your liking, be sure those tabs line back up so you can put the plastic piece back on. Once its all set, pop it right back in as easily as it came out and put the speedometer back into the car.
