Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-07-2007, 10:52 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Oil
so while i have my turbo off, i'm thinking about what kind of oil i should but back in her, well i was running royal purple 5w30 i was thinking of going with a heavier weight because i here its better for turbocharged engines, and was just wondering what you guys run in your cars because i have been running moble 1 5w30 for ever, last oil change was w/ royal purple 5w30, and i here good things about 15w40? and i was thinking about maybe giving amsoil (s/p) a shot? anyone have any comment? used it? like it? dont? why? anything?
Old 11-07-2007, 11:07 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Oil
I think Mobil 1 10w30 would do you well (or any type of synthetic 10w30), it's a bit heavier than 5w30. I don't know if I'd do the 5w30 to 15w40 jump all of a sudden, I know it's just oil, but some cars do weird things when you change types/weights of oils. And being it's a DSM and all, anything is possible.
95 Talon TSI AWD
97 Eclipse GST
Old 11-07-2007, 11:37 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Oil
I run 10-30 synthetic in mine. Switched from 5-30 synthetic. I've got ridiculous oil pressure... Not sure if its from the oil weight swap or not since I added the gauge afterwards. Maybe the BS elimination is a contributing factor also.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 11-08-2007, 09:17 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: Oil
Just changed the oil in the GSX today. Mobil 1 10w30 full synthetic and a mobil 1 oil filter. Thats all I've ever put in it since day 1, and all the last owner said he put in it.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 11-08-2007, 11:21 AM
Sonic Eclipse's Avatar
Sonic Eclipse Sonic Eclipse is offline
Send a message via MSN to Sonic Eclipse Send a message via Yahoo to Sonic Eclipse
Re: Oil
I'm not turbo, but I use to run Pennzoil Full Synthetic 10w30 in my car, but I stopped using it when I discovered a slight oil leak, so I changed it to Pennzoil High Mileage 10w30. It still leaks just a little bit, but not as much as it did when I was running Full Synthetic.
- 1995 Eagle Talon TSi AWD
- 1996 Eagle Talon ESi - 5spd (RIP) -_-
- 1994 Eagle Talon ES - 5spd (sold)
- 1997 Eagle Talon TSi AWD (sold)
- 1990 Nissan 300zx TT (RIP)
Old 11-08-2007, 12:44 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Oil
Its not the best idea to switch to synthetic oil on a motor that has a lot of miles on it. You will most likely get oil leaks. Its best to switch around 1500-2k miles on a new motor.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-09-2007, 12:17 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Oil
My car has seen Mobile 1 10W-30 for the whole life of the car....=)
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 11-09-2007, 10:32 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Oil
I only use Mobil 1 or Castrol GTX synthetic both oils are great.
1991 GSX 2.3 Stroker
Old 11-13-2007, 02:07 PM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Re: Oil
I Run Royal purple 15w50 all day long.
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
