Old 11-07-2007, 09:15 PM
MasterTech8 MasterTech8 is offline
Vibration
I have a vibration while slowing down. The vibration is between 43 and 47 mph. I am not using the brakes. The tires are match mounted and are perfectly balanced, and there are no bent wheels. What else could it be??
Old 11-07-2007, 10:20 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: Vibration
Check for loose u-joints.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 11-08-2007, 10:23 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: Vibration
what year is your truck?
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 11-08-2007, 05:30 PM
Re: Vibration
it is a 2004 silverado z71. i had it at a shop today and checked all u-joints. they were tight. i was talking to a friend about it and he said somthing about "death wobble". i guess it has something to do with the caster numbers during an alignment. could that cause a problem like this or not?
Old 11-09-2007, 05:31 PM
Re: Vibration
It is possible. when was the last time it was in for an alignment?
Old 11-10-2007, 12:36 AM
Silverado6x6 Silverado6x6 is offline
Re: Vibration
Did you change the height front or rear of the truck like a lift kit or lowered the front end?
2002 Silverado 3500 extended cab 4x4 dually
8.1 (496cid) Vortec, Allison 5spd w/OD
All front lights, fog lamps converted to 5000K HID, all running lights chip LED
Modded from LED sign double row red LED sequential T/S, running and brake lights mounted below tailgate.
New side and rear modded emblems for visual effects.
Escalade instrument cluster and auto dim LED outside mirrors.
Front and rear concealed amber Tomar strobe system
Modified for Alaska extremes
Old 11-11-2007, 02:35 PM
Re: Vibration
i just bought a set of tires a few weeks ago. along with the tires i had the alignment checked and they set it and gave me a print out. the numbers were within specs.
no i have not changed the ride height. as far as i know the factory height is still set.
