Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-07-2007, 09:15 PM
gm94 gm94 is offline
98 T/A rough idle
Hi all. This my problem. My 98 TA is having problems with idle. When the vehicle is running is fine. When i'm at idle is a little rough not so bad but recently it started to jerk for like 1/2 a sec like it is going to shut off but it doesn't. The problem doesn't happens all the time but not at the same time intervals. I did notice it more when I stop at a red light. The car had a full tune up (oil, transmission, differential), all filters (air and fuel). There is no codes on the scanner. No check engine light either. I replaced the plugs and wires not too long ago. They were after market ones but look exactly like the original ones. I cleaned the TB with some TB cleaner. I haven't cleaned the MAF sensor but I will as soon as I buy the special cleaner for that. I use seafoam on each oil change. I put one in the gas tank. I do not hear any vacuum leaks but I need a gauge to make sure.
It is not that bad but the the hard jerking like is going to shut off is concerning me. I have been thinking of maybe cleaning the Idle Control Unit but I'm not sure. Any suggestions or things to try ? Thanks.
Old 11-08-2007, 10:04 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 98 T/A rough idle
THAT, is my suggestion biefore slinging parts around.
Old 11-11-2007, 03:50 PM
Ok I cleaned the idle control unit and the MAF sensor. The idle control unit was pretty dirty as well as the MAF sensor.
My iddle is a lot better now but it is still doing the 1/2sec stall like it wants to shut off but it doesn't. Again no codes in the PCM. Don't know what else to try.
I'm going to try to check the fuel pressure and see if it might be problem.
