Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-07-2007, 08:08 PM
Andykid456 Andykid456 is offline
Tranny probablem
Hey i got a 95 gsx when the car is not warmed up it goes in to 3rd gear normal. soon as its warms up it pops out i dont know what it is could you please help thanks.
Old 11-07-2007, 08:34 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Tranny probablem
You need to be more descriptive. What do you mean it "pops out"? Like when driving, or just sitting there? When was the last time you checked the fluid? I suggest switching your tranny fluid to Pennzoil Synchromesh or BG Synchroshift. Going to a higher performance tranny fluid (especially in manuals) usually eliminates or drastically reduces shifting problems, unless you have a bad problem with the synchros, then you're screwed either way.
95 Talon TSI AWD
97 Eclipse GST
Old 11-08-2007, 08:14 PM
It Pops out when im driving so i have been doubel clutching and it goes in fine it usally grinds more if im shifting from high rpms from 2nd to 3rd.
Old 11-09-2007, 12:21 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Sounds like your synchros might be going bad. I second checking your oil. Make sure you have enough oil in there and i would also second the switch to BG Synchroshift or similar oil and see if that helps your problem if not you might need a rebuild.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
