Old 11-07-2007, 06:38 PM
Haulero Haulero is offline
Question keyless problem
hello there, I just programmed a keyless, I follow all steps to do the programing, and it works.... but they key has to be in the ignition in oder to work, if I take the key out, then keyless don't work!! the only way my keyless is working is if the key is in the ignition at the acc position or start up. I thought I was doing something wrong so I went to my local pontiac dealer and the couldn't get it working right either and they say there is something wrong with the system so they need to check whats wrong, it cost 65 to check it... any ideas?
Old 11-07-2007, 07:48 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: keyless problem
Welcome to AF.
It would help to post your year and model Grand Prix
Timeslip 08/12/06
AF Community Guidelines
Old 11-07-2007, 07:55 PM
Re: keyless problem
You are right, sorry. I have a Pontiac Grand Prix GT 1997, got the remote from ebay and they send me programing instruction, but the problem may be with my car 'cause like I said, dealer say the need to check it, but its kinda expansive, 65 just to check it and then more money to fix it :-(
Old 11-07-2007, 08:13 PM
BNaylor's Avatar
Re: keyless problem
Checkout the following link which is in our Tips & Maintenance forum. See if that is the same procedure, if not try it first.
Click here
Timeslip 08/12/06
Old 11-07-2007, 08:23 PM
Re: keyless problem
yes, thats what I do, and doesn't work. well it works... only with the key in the ignition and acc position
Old 11-07-2007, 11:19 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: keyless problem
was keyless entry included from the factory on your car new? Or was is added later? If it was added later, I'd suspect maybe it was wired in incorrectrly.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-13-2007, 05:48 PM
Question Re: keyless problem
its a factory keyless.... I think that car had an alarm, they person that used to own it installed it, that alarm don't work... may be they mess with the keyless wiring while installing that alarm?
