Old 11-07-2007, 05:43 PM
ralphie1968 ralphie1968 is offline
Thumbs down 2000 S-10 abs light
I recently purchased a 2000 S-10. It is a ls model with all the Xtreme add-ons. Lowered, 16 inch rims with 235/55/16 tires. At 70 mph the abs light comes on and stays on with the brake light blinking every 10 to 20 seconds. Once the truck is turned off and restarted the abs light stays on until about 3-5 mph then it goes off and stays off until you get to 70 again. -----The speedometer needle bounces at this speed also-didn`t know if this meant anything or not! Thanks for any ideas
Old 11-07-2007, 06:35 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: 2000 S-10 abs light
You should be able to go to Autozone and get the codes read for free. Write the code down and post it back here. The code will start with the letter C, followed by 4 numbers.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 11-08-2007, 08:17 PM
ricksza's Avatar
ricksza ricksza is offline
The speedometer and the ABS use the vehicle speed sensor in the transmission (two wheel drive) or transfer case (four wheel drive).
The reason the light comes on when you first start it is because there's a code in the system. At 3mph it does a self test. If all looks good at that time, the light goes out until the fault happens again.
Old 11-08-2007, 08:32 PM
Cool Re: 2000 S-10 abs light
If the abs and speedometer use the same sensor could my problem be with this sensor. My speedometer does bounce around at 70 to 75 mph. Thanks for any replies. Oh yeah! local autozone doesn`t have abs code scanner.
Old 11-08-2007, 10:13 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
I second the speed sensor, the ABS system does use the speed sensor for proper operation. Also you mention the speedo is bouncing around.
